What do you think of these Bosch 1000cc High Imp Injectors
dynamix
Re: What do you think of these Bosch 1000cc High Imp Injectors
Post by dynamix »
Just fitted these in mine today and they are good but dont flow quite what they suggest they do unless you up the pressure to them. This would be why the differential pressure is high - they seem to need high pressure.
Sam@TDi
Post by Sam@TDi »
Fair enough, it's just with 9bar (130psi) differential we're off the chart for predicted lag times
pavlo
Zen Performance
Post by pavlo »
Sam,
I settling on 9bar OVERALL max pressure at the pump, we run 6.5 bar differential pressure.
I am just about maxing them out and an 800cc 5th injector running at the same pressure. It is making quite a lot of power.
Sam@TDi
Post by Sam@TDi »
Ah that makes more sense :)
