Just wondering if you have thought about adding a flexi fuel strategy which could utilise a flex fuel sensor.
Here is a writeup I did about a Viper I set up. Should give you an idea of what is possible:
The MoTeC ECU allows a user definable 4th dimension to both the fuel and timing maps (the Z axis). Picture a typical fuel map, only now with up to 11 "layers" that are each a complete fuel map (rpm vs load). In our case I set the flex fuel sensor up to move the system on the "Z" axis, so as the ethanol content changes, it changes to different complete fuel maps automatically. The same happens with the timing maps. All seamless, all automatic based on input from the flex fuel sensor.
So first order of business was a pump gas tune, which ended up in the 700whp range with 10psi boost (very small turbos, instant spool). Wastegate springs were at 5psi, and due to traction issues I set the gear dependant boost up to be 5psi in 1st, 7psi in 2nd, 9psi in 3rd and 10psi in 4th+.
Now we proceeded to fill it with E85, and the flex fuel sensor data changes VERY fast. This of course tracks the system to a different "Z" axis fuel and timing "layer", and we proceeded to tune the car to 15psi of boost and 980whp (we were out of injector and fuel pump). Keep in mind the Motec is controlling the boost, and of course a tank of E85 does not solve our traction issues so this is how it was setup (all auto adjusted based on data from the flex fuel sensor). With the flex fuel sensor reporting back 85% ethanol, the boost targets become the following: 1st gear is 5psi, 2nd gear is 7psi, 3rd gear is 11psi and 4th gear is 15psi.
Now to add a special touch to the driveability, I tweaked the hot/cold start tables to include the incoming flex fuel data (to adjust start fueling based on ethanol content), acceleration enrichment values are trimmed based on ethanol content, etc.
Once the ground work was done, I then tuned a couple of blends to bring the two "ends" as it were together, in a seamless transition of 5 "Z" axis layers to go between pump fuel and E85 (and a couple out the far end in case we run into some strong Kentucky 'shine, given the home state of the car). The boost control shown above also does a linear transition between the two points illustrated above based on ethanol content. The fuel trims/start fueling/etc also have the same transistion tuned into them.
This is all done with one calibration file, no laptop is needed to switch things, it is all automated by the ECU. The car also has a keyed "valet" switch wired in, which allows 4 overall boost settings: minimum boost in all gears, 50% reduction in boost across the gears, 25% reduction in boost across the gears, and then maximum permitted by the control (see above values).
This is the problem, you can buy Race E85 but its not cheap at £3ltr.jezzpalmer wrote:Of course, the UK needs to acquire a good E85 network first; there are two Morrisons stations 'near' to me, but they are 22 and 40 miles away.
Now that's more appealing.Jez wrote:You can get it for 85p + VAT per litre from http://www.greenergy.co.uk if you buy 50 litre drums - although that price was given in November 2008
jezzpalmer wrote:That's a good read, Wez.
I hadn't realised the corrosive properties of E85 (thought it only applied to methanol), that's a pain for my in tank 044, though I guess in E85 land I'm going to be needing 2 external pumps anyway so a steel cased lifter pump can go intal
