Anti Lag System fuel multiplier request
KulinPapa
Post by KulinPapa »
Would it be possible if ALS fuel multiplier could be set between 0.0 and 2.0. (Not only between 0.0 and 1.0) On this way it could be possible to add some fuel in antilag mode if needs. Thanks.
pavlo
Zen Performance
Re: Anti Lag System fuel multiplier request
Post by pavlo »
You don't need more fuel for effective ALS, bearing in mind the anti lag system is there to reduce lag, not to spit flames!
If you want to reduce EGT you need to add fuel cut, as this brings in fresh air which has a big effect and you can easily reduce the EGT even with large amounts of bypass.
If you want to spit big flames then yes perhaps a fuel multiplier would be nice but it will not be nice for the engine to dump lots of fuel.
What problems are you having with it at the moment?
KulinPapa
Post by KulinPapa »
I agree with you. I dont have problems with antilag now. But some of my customers would like to see more flames behind the car. And i thought, it could add more flexibility to the software.
