This may have changed but it needed a firmware update to sort this on the bluetooth itself. (I could be wrong on this so apologise if I am)
If it has been sorted I will order one next week
yes - simply because there is no control of TC CAL via CAN as yet (nor LC on/off) so it has to use an actual input pin, unfortunately.Steve wrote:Tim, just to confirm you are saying use the CANBUS control for CALs and for TC use an input?
Hey Tim, you are correct the BT module is RS232 and the firmware change is to be done by Life.TimH wrote:IIRC, the BT module uses RS232 not CAN? If so, bearing in mind a change to allow control of the ECU via RS232 will be down to Life Racing, my hunch is that it won't happen in a hurry
Could be very wrong of course!
