Logging - doesn't happen.
Re: Logging - doesn't happen.
Will investigate all those points related to logging in due course Paul.
The FP sensor failed giving 0V output. A new sensor is now showing 10bar+ at power up, slowing dropping over minutes as usual (so I know the new sensor is working, although always possible a new sensor is the wrong type or even faulty). I will replace the old mechanical gauge as a sanity check, then dismantle the FPR.
What happens if the log memory is full - does it stop logging, or does it throw away older logs?
pavlo
Zen Performance
Post by pavlo »
If the logging memory is full then it is overwritten. You will only have the last XXX seconds (as shown in SCfg) of logs available, so if you want to record a launch, and you have 422 seconds of logging time then you will need to stop and pull the log within that 422 seconds of the start of the launch.
I am going to guess that you have pulled about 422 seconds of you pootling about some time after your launch experiment.
Can I go and hide under a stone somewhere :oops: :oops: :oops: :oops:
