CAN Bus assignment
David_Wallis
CAN Bus assignment
Post by David_Wallis »
Got a loom to do and have the following CAN devices to attach.
S8
Motec PDM30 + Keypad
Motec C125
ECUMaster Can switch v3 board
Syvecs 50hz GPS
Bosch M4 ABS (and yaw sensor obviously)
Is there any benefit in moving any of the devices to CAN2 - I seem to remember that ABS has to be on CAN1?
(ABS is 1Mbit)
I was previously using custom CAN to integrate with the PDM when I had it on the desk over a year ago.
Lqqk
Re: CAN Bus assignment
Post by Lqqk »
Hi - I’m in the process of setting up a similar setup:
S7+
Motec c125 + 8way keypad
Racegrade - TC8 EGT
3x ECUMaster Canswitch V3
Izze racing 6DOF IMU
4x Izze racing tire temp sensor
Canbus TPMS
My 996tt has a 500k canbus for the gauges and abs.
So I was thinking that canbus1 would be 500k for the integration with the car, and canbus2 be 1mb for the additional canbus sensors. I would then have the c125 connected to both canbus 1 and 2 so that I can reduce the amount of custom canbus templates I would need to create to publish data - not sure if this is the best way to set this up or not?
