fuel cut logic for boost control
Posted: Tue Jan 15, 2019 5:17 am
Seeking clarification on this.
Running 1.87 n54 pnp kit.
I've been having fuel cut kick in to manage manifold pressure where the manifold pressure exceeds manifold target (Wastegate Control -> Manifold Pressure Target) and as modified (reduced) by target adjustment for gear (Calibrations -> Boost Control).
The relevant fuel cut severity appears to be determined under "Limiters -> Manifold Pressure Limiter". However this section also includes its own Pressure Limit maps.
Original I thought the fuel cut strategy under "Limiters -> Manifold Pressure Limiter" was only relevant to the “Pressure Limit Base”.
I feel like “Pressure Limit Base” figures and an aggressive fuel cut strategy were intended to be used as a global safety cap to prevent exceeding MAP sensor range or other safety considerations, but then it seems I am also having this same fuel cut strategy apply to the lower pressure target specified elsewhere.
So would I be right in assuming the "Limiters -> Manifold Pressure Limiter -> Fuel Cut Severity" table applies to both “Pressure Limit Base” OR “Target Limit” (and as modified for gear), whichever is lesser?
Thanks.
Thanks.
