CAN termination
Re: CAN termination
RICE RACING wrote:X10: is on its own CAN link as posted above F88 > X10
Consider for a moment :
An S6 does not have a second CAN bus.....
The X10 may be used with an S6....
The SDM-X00 may be attached to the S6<>X10 link....
I'll leave it up to the imagination of others to infer what the consequences of the above are and how one might address them :)
Re: CAN termination
What's an SDM-X00?
Re: CAN termination
SDM-X00 is my shorthand for SDM-300, SDM-500 and SDM-700, those being the range of Plex dashes that are compatible with CAN running a Slave Link :)
Re: CAN termination
Aha! OK :)
Re: CAN termination
Must have another go at coercing Toucan to work on the Slave link!
Grabla66
Re: CAN termination
Post by Grabla66 »
No issues at the dyno yesterday. X10 worked first time, with no CAN termination added. Just a direct connection between the ECU CAN2 and the X10 CAN1, hi to hi and low to low.
Re: CAN termination
sweet :)
Re: CAN termination
I'm still confused by this...Pat says a termination is needed and is not included in the X10; you both say it is not needed. The last X10 I had here definitely did not have a termination built in, so maybe LR have changed the design recently.
Grabla66
Re: CAN termination
Post by Grabla66 »
My F88 is five years old. If that helps.
Mark_r33
Re: CAN termination
Post by Mark_r33 »
Slight tangent;
Grabla66, what is the connection diagram thing you've got going on here, I like that, very clear
Return to “X10 (Legacy - Gen1)”
