Fuel temperature from flex fuel sensor
Slowie
Post by Slowie »
Hi
The ability to read fuel temperature from a flex fuel sensor would be great, and would save an extra input, in cases where fuel temperature is required.
Re: Fuel temperature from flex fuel sensor
If Syvecs/Life Racing can't do this, I could add it to our Mini Expansion Unit easily enough Image
I think all the flex fuel sensors incorporate this already ?
Not sure whether the ecu is normally configured to accept it though ?
stevieturbo wrote:I think all the flex fuel sensors incorporate this already ?
No, the ECUs don't have support for fuel temp. I asked ages ago.
Also, not all flex fuel sensors measure temperature.
tpepmeie
Post by tpepmeie »
TimH wrote:No, the ECUs don't have support for fuel temp. I asked ages ago.
The Life F88 has a Fuel Correction Multiplier table for Fuel Temp. I figured the Syvecs line would have the same?
Its support for interpreting fuel temperature from the flex sensor that the ecu doesn't have.
As Tim says, you can supply fuel temperature from a regular analogue input....just not via the inbuilt output on a digital flex fuel sensor.
