request assistance to the connection of a s6 on skyline r33
Posted: Fri Apr 22, 2016 1:21 am
Hello friends
I introduce myself I'm christophe and I am french I have a skyline r33 gtr prepared with a 2.7L and a gearbox getrag
I bought a syvecs management but I have small problem for some trendy Module
would you have the opportunity to give me the information pourait afford to finish connecting all went device with schemas if was possible for you
here are the devices that still have to connect before startup
the joystick has two cables
the solenoid and the 3-way valve
the flex fuel
I guess the branch are:
GND = earth OK
out =
Vcc =
Out = I guess that was the + after ignition
Vcc = goes to the box on the AU4 / AN08
I also have two devices plx a plug for my AFR and ETG
it is possible to connect is on the case
because I also have a ntk supplied probe during my purchase
here is the only thing I received with the purchase any item
thank you to you if you will help me to finish the connections
once all that will be mounted I would like to come to England to management sva import is expensive or cheap or rb motorsport syvecs
desolated my English and poor so I go through a translator
cordially
christophe
the flex fuel
GND = earth OK
out =
Vcc =
cordially
christophe
