I now have two calibration switches, one for normal use and the other dedicated for traction control.
They both have red, black and white wires. I am guessing they are the following :-
Black : negative
Red : Reference voltage (guessing +5v)
White : Signal to ECU
As I am using two I want to make sure that both switches can share the same reference (red) and negative (black) feeds to reduce the wiring as I was planning on using a single four way connector, is this correct?
